| Product(s): | WaterSight |
| Version(s): | 10.00. |
| Area: | Documentation |
In WaterSight it is possible to enable the 3D context from any map page. The 3D context includes the 3D terrain, the 3D building outlines and the 3D pipes clamping to the ground. Both 3D terrain and 3D building outlines capabilities are automatically available for the region of interest (the user does not need to upload or import additional information).
To enable the 3D context please follow the below steps:
4. To enable 3D view: move the cube located on the top right of the map
5. You will get a full 3d view, with the pipes automatically clamping to the ground;
Note: in the map layers widget, under the configuration wheel button there are some advanced settings to enhance your 3D experience.
