| Product(s): | WaterSight |
| Version(s): | 10.00. |
| Area: | Documentation |
WaterSight allows the administrator to configure different models views that can be accessed by operators or engineers (through an one single click) so they can easily understand or identify main trends or problems. Example of different views that can be pre-configured:
To configure your model views, please go to Administration >> Numerical Models >> Edit an existent model >> Manage Styles.
Style configurations define how a given element type (pipe or junction) is to be rendered in the results map. The style configuration defines both the color and size configuration for that element type.
The configurations defined on this page will be available from the Model Symbology >> Preset Map Configurations dropdowns on the Current Simulation page. The selected configurations will be applied, and the pipes and nodes will by styled accordingly. Every numerical model comes with a predefined set of "default" style configurations that can be edited, but not deleted.
Figure 1 - Low pressure view.
For more information about WaterSight, please go to OpenFlows WaterSight TechNotes and FAQ's.
