This is WaterSight!
Did you ever wish everyone in your team could see all of your enterprise system data in one common dashboard environment (SCADA, GIS, hydraulic model, customer billing and more)?
Accessible anywhere, at any device, providing access to unlimited users? With such an easy and intuitive interface that can be used by everyone at the utility?
Wouldn't it be helpful if you could investigate the real-time performance as well as forecasts for each asset using an embedded hydraulic model that is continually updated with boundary conditions from sensors? And simulate pipe breaks and understand pump hydraulic performance in near real time?
What if you could detect and geolocate anomalies in your water system and proactively prevent them from happening again in the future?
...and are you:
(And not to worry, our seasoned Digital Integration team can leverage your existing WaterGEMS model to jump start your implementation today.)
These are just a few of the things you can do in WaterSight, Bentley's water distribution system digital twin! Watch the following short videos for a demonstration of WaterSight in action!
Introduction: OpenFlows WaterSight: Turn Your Utility's Data into Action
In depth overview: OpenFlows WaterSight: Complete Solution Walkthrough
Leak detection: Quickly locate leaks with WaterSight!
WaterSight can serve unlimited users in your organization. Annual subscriptions are at affordable costs based on population served. Enterprise Public Sector subscriptions available too for fixed annual fee for all Bentley software use, so you have a predictable budget each year.
Interested? Contact Slavco.Velickov@bentley.com or click here.
See Also:
