| | Applies To | | |
| | Product(s): | PondPack | |
| | Version(s): | CONNECT Edition, V8i | |
| | Area: | Calculations | |
How do I extend my total simulation time to show results beyond 24 hours?
- Go to Analysis > Calculation Options and double click on your current calculation option (the one with the red check mark). This will open the properties.
- Change the "Total simulation time" to the desired duration.
- Re-compute the model. Now you can graph any element and you should see the graph extend to the time you specified as your total simulation time.
Whats New In PondPack V8i [FAQ]
