WaterSight - Managing Users, Roles and Permissions
Product(s): WaterSight
Version(s): 10.00.
Area: Documentation
This article explains how to add users to the digital twin, manage their roles (only viewer VS admin role) or how to control what modules or pages users can have access to.
Managing the Project
Clicking in the Connected Project link, available from the Digital Twin Setup page, or in the plus (+) button under Team members, will redirect the user to the Bentley Connected Project.
From here it is possible to see some of the Project Details (date of creation, who created, country, etc), manage the Team Members that have access to the Digital Twin and also to associate External Organizations.
Note: please make sure you have your organization associated; in case there is no external organization associated, contact your IT/software support, and ask him to associate your Bentley account to your company organization.
More information on how to add users to the organization please click here.
Managing Team Members
Click on the Manage button, below the Team Members section to enter in the Project Team Management page.
From the Project Team Management page it is possible to view all users that have access to the DT. From here it is also possible to add new users or change/set different user roles/permissions.
The Project Team Management page can be also accessed by directly clicking on the "plus" button  located just on the right side of the Team Members, in the Digital Twin Setup page.
Add Team Member
To add a new team member:
It is also possible to automatically import a list of users from a CSV file. The procedure is the following:
Manage Roles
Some important notes:
the first time a user is added, a role needs to be assigned. One of the following profiles should be defined:
The project owner (who created the Digital Twin) will always have access to all WaterSight permissions. Users with the OpenFlows Admin role will be able to add users with the OpenFlows Admin or OpenFlows User role or add/remove those roles from existing users.
To edit an existent user role, select the user for which the role needs to be changed (1), and then click Modify Role(s) (2).
Then select one of the roles of the available roles. From there it is also possible to remove one of the existent roles.
In case some permissions are missing or misconfigured, please click in the Manage Roles button located on the top right side of the users table.
For example if you can not create issues or the form is blocked for you, please make sure that your role has the right permissions defined for the ProjecWise Forms, as shown below.
Manage Access to specific WaterSight pages
A user with OpenFlows Admin role can also control which WaterSight pages users can have access to. It is possible to hide specific page/entries (menus and submenus, such as water audit, pump performance, Customer Analytics, etc) for any specific user or per role of users (user and admin).  To enable or disable specific WaterSight modules and pages go to Admin >> Settings >> Topic Visibility. More information here under topic visibility section.
Managing Users
Creating a New Digital Twin
Managing Users
