| Product(s): | WaterGEMS, SewerGEMS, CivilStorm, StormCAD, PondPack, SewerCAD, HAMMER, WaterCAD | ||
| Version(s): | CONNECT Edition, V8i | ||
| Area: | Output and Reporting |
How can I copy graph or profile data so it can be pasted into an external application like Excel?
In a graph (right click on an element and choose Graph, select the desired attribute) or Profile, click the Data tab in the upper-left corner and click the "Copy" button. Paste into Excel or another external application and you should see the Column Headers as well as the Data.
Copy and paste (import or export) tabular data
How can you export a profile into another format?
