| Product(s): | WaterGEMS, WaterCAD, SewerGEMS, SewerCAD, CivilStorm, HAMMER |
| Area: | Modeling |
When using LoadBuilder, there are no available fields available when selecting the Usage Field.
The Usage Field property is expected to be a numerical formal. Though numbers may be listed in shapefile, check the format for the column to make sure that it is not set as a Text field. If it is, convert this to a numerical field. You should then see this column as being available in the Usage Field pulldown menu
