| Product(s): | WaterCAD, WaterGEMS, HAMMER | ||
| Version(s): | 08.11.XX.XX and higher | ||
| Area: | Output and Reporting |
In WaterCAD, WaterGEMS and HAMMER, what does the "pressure" result represent and what is the difference between pressure head and pressure?
Pressure head is the hydraulic grade minus the physical elevation at a junction or the weight of a given height of water column at its bottom end. It is independent of the amount of water: the pressure head of a 10-foot high or deep 2-inch diameter pipe is the same as that of the 2-foot diameter pipe of the same height or depth (business dictionary.com, 2014).
The pressure reported is simply the hydraulic grade line (HGL) minus the physical elevation of the node, converted into your desired pressure units. It also takes into account the specific gravity of water, which defaults to 0.998. For example, if you have a pressure head of 56.70ft your pressure would be 56.79ft * 0.998 = 56.67 ft of H20.
In water distribution modeling, the "dynamic pressure" is usually negligible compare with the "static" and "total" pressure. Node elements, where pressure is calculated, are usually located at tees and crosses, so the velocity head would be ambiguous.
Note: The water products use a hard-coded conversion factor to convert hydraulic grade (ft) to pressure (psi). This conversion factor is based on the gravity coefficient and properties of water at a given temperature. The conversion from hydraulic grade to pressure should be reasonably close to hand calculations, but this coefficient may be different from the assumptions in the user’s hand calculations. If the user wants to narrow the difference between what the product is reporting and the hand calculations, an adjustment to the specific gravity in the calculation options could be used.
When the user changes the fluid, why doesn't the calculated pump head change?
