| Product(s): | SewerGEMS, CivilStorm, StormCAD, SewerCAD |
| Version(s): | 10.03.04.53 |
| Area: | Installation |
CONNECT Edition Update 3 version 10.03.04.53 of SewerGEMS, CivilStorm, SewerCAD, and StormCAD introduces improvements and features to help you be more successful:
Integration with MicroStation CONNECT Edition is now supported with this release of the OpenFlows storm-sewer products.
AutoCAD 2022 integration is supported starting with this version of the OpenFlows water products. Support for AutoCAD 2021, AutoCAD 2020, and AutoCAD 2019 is also included.
A Select in Drawing option has been included in the Profiles manager. Selecting this will select the elements of the profile in the drawing. You would then be able to create a selection set, add to an existing selection set, or view the properties of the elements in the profile.
You can enter the transparency for the Bing Maps background, using a value from 0% to 100%. If you have an existing model with a Bing Maps background layer you can edit the background layer by right-clicking on the Bing Maps background layer and choosing Edit. When you set the transparency and click OK, the transparency will be updated.
For more information on Bing Maps backgrounds, see this link: Using Bing Maps as a Background Layer.
The Select toolbar, which is used in element selection for features like Active Topology, graphs, and other features, will now reopen in the last location used after it was closed. This can be useful to avoid needing to move the Select toolbar from the middle of the drawing if you have zoomed to a given element you want to select.
Supported Operating Systems
Compatible Platforms
Models saved in earlier versions of SewerGEMS, StormCAD, SewerCAD and CivilStorm can be opened other versions of 10.03.XX.XX.
See: Model backward / forward compatibility
In ModelBuilder, support has been added for connections to Oracle 19c data sources.
As with all new versions, this release includes fixes to various user-reported issues from the previous release, providing an overall more stable experience.
