WaterSight - Maps (Sensors)
Product(s): WaterSight
Version(s): 10.00.
Area: Documentation
All sensors and assets (tanks, pumps) related information can be found and controlled under the Sensors tab, located in the side panel. To turn on/off the sensors on the map, please click in the visibility icon   located on the top, under sensors tab. By default, sensors will be turned on.
Note: Sensors defined with priority 0 in the sensor configuration page (inside Admin) will never be displayed in the map page.
Status
In addition to this, on the top right of each sensor icon, a coloured circle is also displayed. The colour coding is based on time delay of the latest value found in the Sensor's database and depending also in its Communication frequency. More detail below:
Category Symbol Description
Offline  Marked as offline by the administrator*
No Data  (Now – Last InstantInDB) > 4 x MaxLagTime
Partial data  (Now – Last InstantInDB) < 4 x MaxLagTime
OK  (Now – Last InstantInDB) < 2 x MaxLagTime
Where MaxLagTime is
15min + Sensor communication Frequency + Sensor Registration Frequency
Last Instant in DB corresponds to the last time step for which values were registered in the database for each given sensor. This time can be seen under Admin >> Sensors, by looking at Last Instant in DB column. Sensor communication frequency and registration frequency are also defined under Admin >> Sensors
* Sensors can be marked as Offline by the user administrator under Administration > Sensors. Offline sensors can represent sensors that have chronical problems (like no data or flat reading), well know by the utility, and for already a long period of time, and the issue is not expected to be solved soon. The majors advantages of having this category are:
Search
Clicking in the   icon located on the sensor side panel to search for a specific sensor. Restricts the displayed sensors in the map and panel to the text fragment entered into the search field.
Filter
Clicking in   icon located on the side panel to filter sensors. It is used to control the way the sensor list is displayed:
Sort By Description
Alphabetic Sorts the list of sensors ascending in alphabetical order
Asset Sorts the list of sensors by asset (pump, tank or other)
Status Groups the list by status and sorts within groups in alphabetical order
Measurement Groups the list of sensors by their measurement and sorts within the group in alphabetical order
Filters:
Status Description
No data Sensors report significant delay
Partial data Sensor reporting moderate delay
OK Sensor reporting within expected Delay
More information above, under sensor status.
Measurement: Dropdown of measurement options to filter. The sensor measurement is configured under Sensor Configuration, under Administration.
Tag: see the sensors displayed by user defined groups. User defined groups or Tags are defined in the Sensor Configuration, under Administration.
Interacting with Sensors
Sensors are grouped in the map and in the side panel according to the following with the following type of assets:
 Tank
  Pump
   Other
Sensors associated with a tank or with a pump are represented by a tank or pump icon. Sensors that are not associated with either tanks or pumps fit under the others category and are represented by a wifi-symbol. Association of sensors to tanks or pumps is done in the administration > hydraulic structures >> Pumps, Tanks page.
Selecting a Tank
When clicking in a tank icon on the map or side panel, a chart with the level sensor reading for the previous 24 hours is shown together with more information on the side menu.
To exit this view or return to previous view, click on the close (x) icon located in the sensor chart or click on the back arrow   located in the side panel.
Tank chart
Sensor level reading for the previous 24 hours is shown (black line with color coded circles) together with the expected patterns - grey bands (in case patterns are configured in Admin >> sensors). The main goal is to provide an at-a-glance indication if "patterned" variables lie within the expected range of values​. Particularly useful to quickly spot any anomalies in real time.
User can click in the expand button located on the top right of the graph   for more detail. The chart will extend to full page with more options, such as: navigating in the time series history, create event button shortcut, changing pattern or time series-interval, adding model results or raw data, etc. More information in the sensor details help-page.
Schematic
Provides an at-a-glance indication in real time if tank levels are above or below minimum or maximum values defined (for the last 15 minutes average). If tank level is below the minimum value defined in the Tanks Configuration page, it will appear color-coded with a red color. If tank level is above the maximum value defined in the Tank Configuration page, it will appear color coded with an orange color. Average value is represented with dash line and corresponds to the expected tank level for the current time (obtained based on the percentile 50 of the level historical data).
Sensors
Level sensors associated with the tank. If a red warning is displayed along with the sensor name, this mean that there are active events associated to that sensor that need attention. Click on the sensor level to open the sensor detail. More information below under the section "Selecting a sensor".
Details  Details
By clicking in the details button the user will be redirected to thethe user will be redirected to the Sensor details page with more options, such as: navigating in the time series history, create event button shortcut, changing pattern or time series-interval, adding model results or raw data, etc. More information in the sensor details help-page.
Selecting a Pump
When clicking in a pump icon on the map or side panel, a chart with the pump flow-head curve for the last week is shown together with more information on the side menu.
Pump chart
Displays the pump head vs. flow curve, together with pump operating points (flow vs head), for the last week. Main goal is to provide an at-a-glance indication if pumps are operating near the expected range of values​. Particularly useful to quickly spot pumps that are beginning to fail, or are operating in an inefficient manner.
Pump flows are obtained based on the pump flow sensor signal. Pump heads are calculated based on the suction  signal and discharge signal, which can be either pressure or level signals. If the flow or discharge signals are not configured, the operating points will not be calculated. If the suction signal is not configured, the suction pressure will be assumed to be 0.
User can click in the expand button located on the top right of the graph   for more detail. The chart will extend to full page with more options, such as: managing time series, enabling efficiency and power curve, etc . More information in the pump details help-page.
Average Performance
Average performance variables (flow, head, efficiency, power, best efficiency, efficiency deviation) for the period defined under Manage Series. If multiple series are selected, this displays the average across all series. Efficiency values are calculated based on pumps flow, head and power.
Invalid Efficiency points: percentage of points that were excluded from the analysis for the defined time period. Invalid points are excluded from the calculation of the pump efficiency and are also not displayed on the pump graphs. This includes for example cases:
Realtime Performance
Real time values for each pump: flow, head, efficiency, power and speed. Efficiency values are calculated based on pumps flow, head and power.
Sensors
Sensors associated to the pump (defined in the administration). If a red warning is displayed along with the sensor name, this mean that there are active events associated to that sensor that need attention. Clicking directly on the name of each sensor will directly redirect the user to the sensor detail (see "Selecting a Sensor" section below)
Details Details
By clicking in the details button  the user will be redirected to the pump details page with more options, such as: navigating in the time series history, create event button shortcut, changing pattern or time series-interval, adding model results or raw data, etc. More information in the pump details page.
Selecting other Sensor (neither pump or tank)
When clicking in a sensor (wi-fi symbol) from the map or in a sensor on the side panel (located under the assets tank, pump or others), a chart with sensor reading for the previous 24 hours is shown together with more information on the side menu.
Empty heading
Sensor chart
Sensor reading for the previous 24 hours is shown (black line with color coded circles) together with the expected patterns - grey bands (in case patterns are configured in Admin >> sensors). The main goal is to provide an at-a-glance indication if "patterned" variables lie within the expected range of values​. Particularly useful to quickly spot any anomalies (that can represent bursts, leaks, tank overflows, pressure problems, maintenance works, etc) in real time.
Sensor Details
Sensor Tag: The signal tag in the database associated with the sensor
Type: Type of measurement
Pattern: Pattern group assigned to the sensor. Pattern groups can be created the the Administration > Settings > Pattern and assigned to sensors in the Admin > Sensors configuration page. If Pattern None is selected, then no patterns will be computed and displayed in the sensor graph. Patterns are displayed in the sensors graphs as grey bands.
Status: Ok (reporting within expected delay), Partial (reporting moderate delay) and no data ( reporting significant delay) More information above, under Status section.
Latest: The timestamp of the latest signal reading.
Statistic
Field Description
Minimum (p05) Percentile 5 of the last 3 months, for the 15 minutes time-series.
Median (p50) Percentile 50 of the last 3 months, for the 15 minutes time-series.
Maximum (p95) Percentile 95 of the last 3 months, for the 15 minutes time-series.
Minimum/Median
Ratio of "Minimum (p05)"and "Median (p50)" of the of the historical time period defined by the user (default is last 3 months), for the 15 minutes time-series.
Active Events
The 5 most recent events associated with the sensor will be displayed. For the full list, click below in Details.
The user can directly jump to the event detail by clicking in the alert ID (on the short list or in the full list). From the events details page the user can manage the event, such as change status, category and make comments.
Compare
By clicking in the compare button   the user will be redirected to the comparison page where he will be able to simultaneously compare in the same graph any user defined variable.
Details  Details
Network Monitoring - Maps
Network Monitoring - Graphs
