| Product(s): | WaterCAD, WaterGEMS |
| Version(s): | 10.03.05.03 and 10.03.05.05 |
| Area: | Installation |
CONNECT Edition Update 3 version 10.03.05.XX of WaterGEMS and WaterCAD introduces improvements and features to help you be more successful.
Note: this was initially released as version number 10.03.05.03 and later re-released as version 10.03.05.05 to fix the issue mentioned in this article.
Stability enhancements and fixes to reported issues
Integration with MicroStation CONNECT Edition is now supported with this release of WaterGEMS and WaterCAD. If there are issues related to integration, see this link: Troubleshooting MicroStation integration.
A few additional updates have been included for the automated fire flow run in WaterGEMS and WaterCAD. This includes additional details in the Fire Flow Status. If a fire flow node fails, the Fire Flow Status will include better information on the cause of the failure. The following link has information on automated fire flow: Understanding Automated Fire Flow Results.
Compatible Operating Systems
Supported Platforms:
Models saved in build 10.03.05.XX of WaterGEMS and WaterCAD can be opened in other 10.03.XX.XX releases. Older model files can be opened in the latest version without issue.
See also: Model backward / forward compatibility
As with all new versions, this release of WaterGEMS and WaterCAD includes fixes to various user-reported issues from the previous release, providing an overall more stable experience.
WaterGEMS and WaterCAD TechNotes and FAQs
Downloading OpenFlows / Hydraulics and Hydrology Software
Cumulative patch set information
Set up notifications for new versions and patch set releases
