If you're new to WaterSight, an overview can be found at This is WaterSight.
Also, new user training can be found in this video: OpenFlows WaterSight: Complete Solution Walkthrough
If you are an Administrator setting up the Digital Twin for the first time, start at the New Administrator Guide.
See the Context Sensitive Help for a list of help topics by each page in WaterSight.
This is a list of TechNotes and frequently asked questions. If you have a question, check to see if it's been answered here.
A list of the articles that describe the latest functionalities in WaterSight can be found here.
PowerBI Guide: A guide on how to create and add PowerBI reports into WaterSight.
WaterGEMS Setup Guide: Preparing a WaterGEMS model for real time simulation in WaterSight. Includes a video with a detail demonstration
OFOSC and RestAPI Detailed Guide: A guide on how to set up and configure the connection in order to automatically bring time series data into WaterSight. A brief summary containing the main requirements can be found here - Sensor Data Acquisition Requirements. For more complete detail, please ask your Bentley point of contact for the OFOSC and RestAPI Detailed Guide.
Sensors Quick Guide: Quick guide on how to add and update new sensors
Pump Configuration Guide: A quick guide on how to configure pumps in WaterSight.
If you have a question that isn't covered by any of the above resources check here.
