| Product(s): | WaterSight |
| Version(s): | 10.00. |
| Area: | Documentation |
The graph comparison page allows the user to:
There are different ways of accessing this page:
Note - importance of associating or comparing large customers flows with zones flow, to improve response to zone alerts. Whenever a zone alert is automatically generated by the solution, and in case that zone includes large customers with smart meter data, please make sure to always compare zone flow with the large customer flow to discard potential consumptions. Another option is to create a new zone and include, in the zone balance, the large customers as outflow of the area. In this case, whenever a zone alert is generated, the customer consumption is already discarded (please make sure the original zone with the large customer included is also kept, so we can correctly track the water balance components for the zone).
The very first time the user accedes the Comparison page, it will display an empty page. To add and save a new graph:
To create and save another new graph comparison in case there is at least one created:
Series Tree
The variables or measurements to be selected are grouped in the following categories:
The user can select multiple series from the different categories mentioned above and also select within the different parameters available. Below the parameters available when selecting the Sensor or Large Customer categories:
Clear Series
It is also possible to clear all the selected variables with one single click by pressing the Clear button located on the bottom of the right side panel.
Show selected Series
It is also possible to expand the series-tree to show in the right side panel the variables that are displayed in the graph by pressing the "Show selected in Series-tree button" , also located on the bottom of the right side panel.
Comparing different time periods
To enable the different time serious periods comparison, select a category and a parameter, and then click on the plus button that appears on the right:
Select the time offset by filling the information in the pop-up dialog and click Ok:
New series will be overlayed as a graph dash line. These new series are generated “on the fly” and do not get saved.
Fig 1. Comparing current flow with the flow last week (7 days back in time)
After the graph has been saved, it will be made available every time the user accesses the comparison page. To select one of the saved graphs, just select the desired one from the full list by using the dropdown button located on the top left of the page.
Select the graph comparison to be deleted by selecting from the dropdown list located on the top left, and then click on Delete button located on the top of the right side panel.
Use the graphic toolbar to control the display of the charts:
| Entry | Description |
| Turn on/off legend for the graphs | |
- Turn on/off "Range slider option" in graphs and define the time period for the range slider (last 3 months, last 6 months, last year, last 2 years) - Turn on/off overlay mode (more information below) - Select the Time range to be displayed and available in the graph comparison | |
| Download data that is being displayed on graphs (PNG or CSV format) | |
More graph configurations: spike lines, data tooltip and font size. |
Overlay mode or adjusting Y axis scale for each time series
Sometimes may be difficult to compare different measurements between them and understand the different correlations if their y scale is very different. In that case, to better understand the correlations between the variables the user should turn on the overlay mode (or auto-scale mode) where all the variables are automatically scaled with different y axis so it is easier for the user to understand possible correlations.
The user can also click on the setting button to adjust the y axis range for each parameter
