| Product(s): | WaterSight |
| Version(s): | 10.00. |
| Area: | Documentation |
Select what to configure:
| Sensor trigger |
| Combined Condition (this page) |
| Subscriber Groups |
The combined condition alert can be useful when the user wants to combine the different symptoms that can lead/indicate the same event, such as:
Each example above has different symptoms (conditions) that lead to the same event and the main goal is to minimize false positives.
The combined condition trigger is flexible enough for the users to select as many conditions as they want, and to define a AND or OR conditions.
For each combined condition there is a primary trigger. Once a combined event is generated, the alert graph detail as well as the event properties such as max value and volume lost are related to this primary trigger. Volume lost in combined events is only calculated if the primary trigger is a flow increase (high pattern/high absolute condition).
By using the "All False" option at the bottom, the user can specify an event to be generated when the secondary conditions rules defined are NOT met.
The user can directly move from the event graph detail (which is related to the primary trigger) to the graph where all conditions are represented, by clicking in the graph comparison shortcut from the event graph detail page.
Figure 1 - Combined Event graph detail (accessible from the Active event list or from the sensor/zone graph related to the primary trigger)
Figure 2 - Graph comparison where all conditions are represented in one graph (accessible from the graph comparison shortcut presented in the combined alert detail graph - Figure 1)
