| Product(s): | WaterSight |
| Version(s): | 10.00. |
| Area: | Documentation |
The Maps page gathers the following information in one single view: Sensors, Zones, Large Customers, Events, Map Layers (GIS), Reality Data and Hydraulic Model.
By default pipes layer, sensors, zones (with status information) and associated active events are displayed in the map. Hydraulic Model will be off. The user can control what gets displayed through the side panel. The user can also directly interact with the different type of information directly through the map (by clicking on the elements) or through the side panel.
Side Panel Configuration
The side panel is resizable and can be docked and rearranged in different locations (on the right, on the left, on the top or at the bottom of the page, etc). It is also possible to switch the order of the several tabs (sensors, zones, reality data, map layers). To move each panel tab just drag the desired tab and drop it in the desired location. The panels are also collapsible or can be docked (by pressing the unpin widget located on the top right ).
Below some examples of different configurations for the maps page. Configuration views are saved per user basis, this means that every time each user returns to the application and to the map page, he will see its own view configuration.
Side Panel Interaction
For more information on how to interact with the different type of data and menu widgets (side panel), take a look at below links:
| Sensors (click here) | |
| Zones (click here) | |
| Large Customers (click here) | |
| Map Layers/ GIS (click here) | |
| Reality Data (click here) | |
| Hydraulic Model (click here) |
2D vs 3D view
Move the cube located on the top right of the page to skip form a traditional 2D top view to a 3D view. To have a full 3D experience, please make sure that the Base Map layer is "Aerial" (under the Map Layers tab) and activate the "OSM Building Outlines", under the Reality data tab.
See also
