| Product(s): | Hevacomp Mechanical Designer | ||
| Version(s): | V8i | ||
| Area: | Netsys Ductwork | ||
| Subarea: | N/A |
Roughness values used in Netsys Duct sizing calculations are dependant on the type of ductwork being used.
The following table displays the roughness value for each ductwork type:
| Ductwork type | Roughness |
| Circular galvanised sheet | 0.15 |
| Circular spirally wound | 0.075 |
| Rectangular galvanised sheet | 0.15 |
| Flat oval | 0.075 |
| Flexible | 3 |
