| Product(s): | Bentley Hevacomp | ||
| Version(s): | V8i (N/A) | ||
| Area: | N/A | ||
| Subarea: | N/A |
The following figures are used by the Netsys Pipe sizing program.
| Range | Roughness | Range | Roughness | Range | Roughness |
| Steel BS 1387 Medium | 0.046 | Steel BS 1387 Heavy | 0.046 | Galvanised BS 1387 | 0.15 |
| Copper BS 2871 Table X | 0.0015 | Copper BS 2871 Table Y | 0.0015 | Copper BS 2871 Table Z | 0.0015 |
| PVC-U BS 3505 Class E | 0.003 | Mapress DIN 2394 Heating Pipes | 0.01 | Mapress DVGW W 541 Water Pipes | 0.0015 |
| Microbore Pipework BS 2871 Table X | 0.003 | Microbore Pipework BS 2871 Table Y | 0.003 | MDPE (80) for gas upto 3 bar | 0.003 |
| MDPE (80) for gas upto 5.5 bar | 0.003 | Polybutylene PB 4137 | 0.007 | MDPE (80) For Water upto 8 bar | 0.003 |
| MDPE (80) For Water upto 12.5 bar | 0.003 | ISO Stainless Steel Pipes T=1.6 to 2.6 | 0.005 | PVC-C | 0.007 |
| ABS Pipework PN10 | 0.003 | ClimaTherm SDR 7.4 | 0.007 | ClimaTherm SDR 11 | 0.007 |
| FusioTherm SDR 11 | 0.007 | Fusiotherm Faser SDR 7.4 | 0.007 | Copper BS 2871 Table X Full Range | 0.0015 |
| Rautherm Universal/S | 0.007 | Rautherm Universal/RAUHIS | 0.007 | Rautherm Universal | 0.007 |
| Rautherm S | 0.007 | RAUHIS | 0.007 | Rautherm Pipe in Corrugated Sleeve | 0.007 |
| Uponor MLC (Unipipe) Pipework | 0.0004 | Yorkshire Fittings Xpress Galvanised CS | 0.01 | Yorkshire Fittings Xpress Copper | 0.0015 |
| Friatherm Hot/Cold Pipework System | 0.007 | SuperFlo Chilled/Cold Water (3m) | 0.003 | SuperFlo Chilled/Cold Water (6m) | 0.003 |
| Wefatherm Pipe System PPR (SDR 11) | 0.007 | Wefatherm Pipe System PPR (SDR 7,4) | 0.007 | Wefatherm Pipe System PPR (SDR 6) | 0.007 |
| Wefatherm Stabi System PPR (SDR 6) | 0.007 | Wefatherm Stabi System PPR (SDR 6/UV) | 0.007 | Wefatherm Fiber System PPR (SDR 7,4) | 0.007 |
| Geberit Mapress Carbon Steel System | 0.01 | Geberit Mapress Stainless Steel System | 0.0015 | Geberit Mapress Copper System | 0.001 |
| Geberit Mepla System | 0.007 |
If you are using this information to help choose an equivalent pipe range to one we have not considered, this table of pipe sizes should be useful. The Netsys program sizes using the Nominal diameter of its pipe types.
