| Product(s): | Bentley Hevacomp | ||
| Version(s): | V8i (V26) | ||
| Area: | N/A | ||
| Subarea: | N/A |
After a Windows 10 update, the software may generate Run Time Error 482 when attempting to access the printer or use printer derived functions such as scaling annotation.
There is an issue that is blocking access to the printer or printer driver. Working through the following should resolve this issue.
Open the Control Panel, double-click the Printers icon and choose Add Printer to install a printer.
Turn the printer on, or physically switch it to online mode.
Physically correct the problem
Switch to an installed printer that can handle graphics
