| Product(s): | Bentley I/RAS B | ||
| Version(s): | All | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
The Engineer Tools, now available in MicroStation I/RAS B, offer a real solution to the challenge of converting existing engineering, manufacturing, and facilities drawings. It streamlines and accelerates the conversion/vectorization process.
Below are the steps involved for a general workflow to take a hard copy of a drawing and produce a file that represents the original data in vector format.
Raster Product TechNotes And FAQs
