What are .aux.xml files and what creates them
  Product(s): MicroStation
  Version(s): 08.11.07.443
  Environment:  N/A
  Area:  Raster
  Subarea:
  Original Author: Frank McAllister, Bentley Technical Support Group
Have files with .aux.xml file extensions with same name as raster images. What are the
.aux.xml files and what creates them?
Anytime ArcGIS handles a raster dataset that is stored on the file system, an .AUX file is created. An .AUX file is also created if the raster dataset is used with ArcObjects code, or browsed to in ArcGIS.
The .AUX file is stored on disk in the same location as the raster dataset. The exception to this rule is when the folder containing the raster dataset is read-only. In this case, the .AUX file is stored in the RasterProxies folder.
An AUX file tends to be small, however if they are created for thousands of raster datasets, they can potentially take up a large amount of hard disk space.
It should be noted that with ArcGIS 9.2 and beyond, an AUX.XML file may be created for some raster formats - for the same reason.
http://support.esri.com/en/knowledgebase/techarticles/detail/32344
http://forums.esri.com/Thread.asp?c=93&f=1170&t=245766
http://webhelp.esri.com/arcgiSDEsktop/9.3/index.cfm?TopicName=About_auxiliary_files
