| Product(s): | Mechanical and Electrical Designer | ||
| Version(s): | V8i (25) | ||
| Area: | N/A | ||
| Subarea: | N/A |
The final version of Bentley Hevacomp V8i (v25) consists of three parts:
Download instructions for the main installer parts (1 and 2) can be found here. The final service pack will be considered later.
All three parts must be installed to ensure you have the final version of v25.
We advise logging on as Full Administrator and turning down User Account Control before following the steps below.
During the installation process you will be asked to activate your software.
Ensure you have the main installer parts, and the final service pack.
Run (right-clicking and selecting Run As Administrator is advised) the Hevacomp V8i v25 Prerequisite installer
HCPQ25000008en.exe
Run the main design software installation by double clicking the file
HCOMP25000022en.MSI
You should now consult the document for downloading and installing the final service pack. This can be found here.
