| Product(s): | All Hevacomp Products | ||
| Version(s): | V8i (25) | ||
| Area: | N/A | ||
| Subarea: | N/A |
This document refers to Version 25 Bentley Hevacomp V8i only
There are a number of permissions that the user account requires to be able to run the Hevacomp software correctly. Without these permissions, the user may experience these errors:
A lack of permissions can also lead to a "Cannot create Meteonorm Weather file" and a consequent "Error 9 - subscript out of range" error when trying to create weather locations or access weather data.
To remedy these potential issues, the user must be allowed FULL permissions to a number of locations.
The user will need full permissions to the following:
<installation folder>\Heva25\
C:\Hevacomp Projects\
During the setup of the software you will be asked to specify a location where projects are to be stored - this is frequently a mapped share - the user will also need full permissions into here.
