| Product(s): | ContextCapture Center | ||
| Version(s): | N\A | ||
| Area: | N/A | ||
| Subarea: | N\A |
How to set up ContextCapture Center in a local cluster environment
ContextCapture Center is dedicated to larger-scale 3D surveying and mapping. It can handle an unlimited number of photographs without any limitation in size, and allows computations to be parallelized on a cluster of 3D reconstruction engines.
communities.bentley.com/.../272446
| Original Author: | Felix James |
