Unable to edit raster images in a DWG design file
 Product(s):MicroStation
 Version(s):08.11.09.829
 Environment:N\A
 Area:Raster
 Subarea:N\A
I am unable to edit raster images that are attached in Raster Manager.
In MicroStation you can do File > Save As and create a DGN design file from your DWG design file.  You can open your DGN file in MicroStation or Descartes. In Raster Manager change the raster image from Read-Only to Read-Write.  You can then edit your raster images.  When you open your DWG files the edits will then be shown in your raster images.
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0012924
 Original Author:Frank McAllister
