| Version(s): | 08.11.09.459 | ||
| Area: | Raster Manager | ||
| Subarea: | N/A | ||
| Original Author: | Frank McAllister, Bentley Technical Support Group | ||
I am using a DWG file and have a TIF image attached. I am unable to change the TIF image from Read-Only to Read/Write mode.
In order to change a raster image in a DWG file from Read-Only to Read/Write you must use Descartes.
