| Version(s): | 08.11.09.459 | ||
| Area: | Programming | ||
| Subarea: | VBA | ||
| Original Author: | Sven Zigelski, Bentley Technical Support Group | ||
I want to delete all models of a DGN with a keyin. But there is no keyin available. How to solve this Problem?
The Task can be done with MVBA
Sub delete_all_models()
Dim oMods As ModelReferences
Dim oMod As ModelReference
Dim i As Long
Set oMods = ActiveDesignFile.Models
oMods(1).Activate
For i = 2 To oMods.Count
oMods.Delete oMods(2)
Next
End Sub
(by Artur Goldsweer)
This macro will jump to the model with the lowest index and will delete the next higher until there are no models left excepting the indelible standard model.
