MicroStation CONNECT Edition is one of the largest software undertakings Bentley has taken since the initial release of MicroStation V8. This special edition of the BDN Newsletter will provide an overview of what programming options are available in the new MicroStation CONNECT Edition and MDL SDK. Please take a moment to review the detailed contents of this extended newsletter. Questions regarding support issues for the MicroStation CONNECT Edition SDK should be posted in the Bentley Communities MicroStation Programming Forum. |
How to Download and Explore the MicroStation CONNECT SDK - Video Overview
Programming Options with MicroStation CONNECT EditionWhether you are a MicroStation user, CADD administrator, someone interested in getting started with programming in MicroStation, or an intermediate to advanced software developer; MicroStation CONNECT Edition provides everyone options suited toward your individual level of experience and needs. The graphic below helps illustrate each of the options available, what knowledge each solution requires, and the progression users with no programming experience can work towards someday creating the most robust MicroStation programming solutions possible. |
MicroStation CONNECT Edition SDK OverviewThe following sections describe new features within the new SDK. It should be noted that MicroStation CONNECT Edition SDK requires Microsoft Visual Studio 2013. Reorganized and Refactored: APIs, includes, and libraries Completely New: Native MDL C++ and Managed MDL .NET APIs Leverage MicroStation's GUI administrative tools to make creating and designing common UI components with ease. Choose to extend your application UI using your choice of preferred UI development APIs; like:
Enhanced: MicroStation Developer Shell. The MicroStation Developer shell title bar can quickly determine:
Pathing includes the standard development tools and the new MigrationTools Updated: Many new code samples A "legacy" MDL samples directory is provided as a point of reference when performing 1:1 application migrations. Exploring the new API programming samples and documentation, ensures you will find practical, modern, and preferred coding samples using the most recent MicroStation APIs. Updated: API Documentation
New: MigrationTools A majority of MDL developers are likely to take a 1:1 migration path first. The MigrationTools directory provides a convenient starting point to remap (search and replace) over 2800 common items within your project source code files. Consider using migrate.bat as your first pass in a 1:1 migration. Since it performs these common, repetitive, and possibly error prone tasks:
Please note: the MigrationTools require the download and installation of Python 2.7. The resulting Zip file generated is not intended to replace a well-founded backup solution or strategy. Always make sure to back up your source code and/or source code management system data regularly |
Overview: Migration ToolsThe MigrationTools directory provided in the MDL SDK is an entry point to help developers get started when performing a 1:1 source code migration of existing MicroStation V8 MDL applications to MicroStation CONNECT Edition. As with all source code projects, a good backup and branching strategy is highly recommended prior to performing bulk or unintended edits of your source code files necessary when migrating to a new product version. With that said and your backup complete, let's take a look at the purpose of Migrate.bat and the delivered files and their purpose. Migrate.bat
NOTES: If a prior zip file in the naming convention of ParentDirectoryName.zip is encountered the file will be renamed to include the Current Time backup was performed as part of the new file name, then the current project files will be added to ParentDirectoryName.zip. A future update will likely change the behavior to rename the file to use the LastModified date and time of the original file vs. the current method. After running Migrate.bat and reviewing the report results your next step will be to attempt to compile each migrated application under your parent project. If you have not done so, we highly recommend to confirm the integrity of your development environment by compiling one or more of the delivered MDL example projects (e.g. ..\examples\buildallexamples.bat) from the MicroStation Developer Shell. Once you can compile the delivered examples you should attempt to compile one of your applications with confidence having been processed by the MigrationTools. Please note that unless you have the most basic app, you can and should expect to make several iterative passes: compiling, searching includes and forums, making edits, and re-compile; until you finally have an MDL application converted and ready to run in MicroStation CONNECT Edition. This process is typical of what application developers are required to perform when migrating a source code project from a major version change of product; like when going from MicroStation v08 to MicroStation v10. Applying the steps above should help provide a productive first step to assist in your migration efforts. Depending on your application complexity, substantial product and API changes and your need for input and guidance, or skills and timelines; below are some relevant links for finding some additional assistance. For more information on Migrating to CONNECT please visit: Developers Migrating to MicroStation CONNECT |
ResourcesWhether you are new to MicroStation Programming or the BDN program, or a seasoned developer familiar with both; it is good to have a list of high-level links to make sure you can find the right information you need quickly. Below is a list of useful links to help get you started in the right direction. Please note the second set of links requires BDN membership to obtain access. |
