Early Access Preview - Make File Updates for external User Acceptance Testing.
NOTES:
| MicroStation CONNECT Edition SDK U14 EAP |
The Early Access Preview Make Files are provided to test, confirm and/or provide Bentley further feedback and suggestions in a timely and convenient manner. Please reply to existing (or New) Forum posts if helpful or problems encountered. These updates provide modified MKI file providing better Visual Studio 2017 integration. These SDK Preview files only apply to MicroStation CONNECT Edition SDK (Update 12 and 13 only) will only be available and valid until the next Commercial Release SDK at which time a Clean Install is required and the file link removed and this note archived. |
