The VBA method .CreateDimensionElement1 can be used to create dimension elements.
The syntax for this method is:
Set DimensionElement = object.CreateDimensionElement1 (Template, Rotation, Type [, TextOrientationView])
where Type is a MsDimType expression and allows to create dimension elements of different types.
The MsDimType enum includes the following list:
msdDimTypeUseActive -1 (&HFFFFFFFF) msdDimTypeNone 0 (&H0) msdDimTypeSizeArrow 1 (&H1) msdDimTypeSizeStroke 2 (&H2) msdDimTypeLocateSingle 3 (&H3) msdDimTypeLocateStacked 4 (&H4) msdDimTypeAngleSize 5 (&H5) msdDimTypeArcSize 6 (&H6) msdDimTypeAngleLocation 7 (&H7) msdDimTypeArcLocation 8 (&H8) msdDimTypeAngleLines 9 (&H9) msdDimTypeAngleAxis 10 (&HA) msdDimTypeRadius 11 (&HB) msdDimTypeDiameter 12 (&HC) msdDimTypeDiameterPara 13 (&HD) msdDimTypeDiameterPerp 14 (&HE) msdDimTypeCustomLinear 15 (&HF) msdDimTypeOrdinate 16 (&H10) msdDimTypeRadiusExtended 17 (&H11) msdDimTypeDiameterExtended 18 (&H12) msdDimTypeCenter 19 (&H13) msdDimTypeAngleAxisX 50 (&H32) msdDimTypeAngleAxisY 51 (&H33) msdDimTypeLabelLine 52 (&H34) msdDimTypeNote 53 (&H35)
Here a small VBA code example using the type msdDimTypeNote to place a Note:
Option Explicit Sub placeNoteExample() Dim oDim As DimensionElement Dim oDimStyle As DimensionStyle ' Create a new DimensionElement of type Note: Set oDim = CreateDimensionElement1(Nothing, Matrix3dIdentity, msdDimTypeNote) oDim.AddReferencePoint ActiveModelReference, Point3dZero oDim.AddReferencePoint ActiveModelReference, Point3dFromXYZ(10, 20, 0) oDim.AddReferencePoint ActiveModelReference, Point3dFromXYZ(20, 20, 0) ' if required use a specific available dimensionstyle: Set oDimStyle = ActiveDesignFile.DimensionStyles("teststyle") oDim.DimensionStyle = oDimStyle ' Define note text: oDim.PrimaryText = "test" ' Place element into active model: ActiveModelReference.AddElement oDim End Sub
