Properties from attached raster files in MicroStation can be modified using the Rastermanager.
Also VBA supports the Rastermanager to modify these properties.
The following VBA example is demonstrating how an attached raster file can be selected and the position changed, scaled and rotated.
Sub ModifyRaster() Dim oRaster As Raster Dim origin As Point3d Dim size As Point2d Dim rotat As Double Set oRaster = RasterManager.Rasters.Item("D:\raster\test.jpg") Debug.Print "Filename: " & oRaster.RasterInformation.Name ' Modifying size: size = oRaster.GeoReferenceInformation.Extent Debug.Print "Old size(xy): " & size.X, size.Y ' scale size with 1.5 size.X = size.X * 1.5 size.Y = size.Y * 1.5 oRaster.GeoReferenceInformation.Extent = size Debug.Print "New size(xy): " & oRaster.GeoReferenceInformation.Extent.X, oRaster.GeoReferenceInformation.Extent.Y ' Modifying origin: origin = oRaster.GeoReferenceInformation.origin Debug.Print "Old origin (xy): " & origin.X, origin.Y ' set new origin: origin = Point3dFromXYZ(150, 250, 0) oRaster.GeoReferenceInformation.origin = origin Debug.Print "New Origin (xy): " & oRaster.GeoReferenceInformation.origin.X, oRaster.GeoReferenceInformation.origin.Y ' Rotate raster: rotat = oRaster.GeoReferenceInformation.RotationAboutZ Debug.Print "old rotation (degrees): " & Degrees(rotat) & "°" rotat = Radians(65) ' rotate about 65° oRaster.GeoReferenceInformation.RotationAboutZ = rotat Debug.Print "new rotation (degrees): " & Degrees(oRaster.GeoReferenceInformation.RotationAboutZ) & "°" End Sub
