How to use Descartes' Point Cloud processing tools
How to use Edit Classification tool  to remove points from a Point Cloud and use it to support retrofitting project
How to extract a regular grid of terrain points from a Point Cloud
How to extract wires from Point Cloud (Transmission line, Rail overhead lines...)
Introducing Flashlight (part1) - how to extract edges/breaklines
Introducing Flashlight (part2) - how to avoid snapping mistakes
Extracting cylinder & plane
Extract Section of Wall with overhangs
