CRUD example
The following small code example describes how to
Option Explicit ' always recommended to use. Makes sure all variable are declared before use
Private elementID As DLong
Sub ArcCreate()
' Create ArcElement
Dim oArc As ArcElement
Dim p(2) As Point3d
p(0) = Point3dZero
p(1) = Point3dOne
p(2) = Point3dFromXYZ(2, 0, 0)
Set oArc = CreateArcElement3(Nothing, p(0), p(1), p(2)) ' This is one of 6 different functions to create an arc
ActiveModelReference.AddElement oArc ' after creation the elements needs to be added to the active model
elementID = oArc.ID
End Sub
Sub ArcSearchAndModify()
' Scan active model for arcs and change some properties
Dim ee As ElementEnumerator
Dim sc As New ElementScanCriteria ' Scan criteria to search for specific attributes
sc.ExcludeAllTypes
sc.IncludeType msdElementTypeArc ' search for arcs
Set ee = ActiveModelReference.Scan(sc) ' scan active model for all elements matching the scan citeria
Do While ee.MoveNext
Set oArc = ee.Current.AsArcElement
Dim pCenter As Point3d
pCenter = oArc.CenterPoint
Dim pMove As Point3d
pMove = Point3dFromXYZ(1, -1, -1)
oArc.Move pMove
oArc.PrimaryRadius = oArc.PrimaryRadius * 1.2
oArc.Color = 11
oArc.LineWeight = 4
Set oArc.LineStyle = ActiveDesignFile.LineStyles(5)
oArc.Rewrite ' important to rewrite element in the designfile to save changes
Loop
End Sub
Sub ArcDelete()
'on error resume next
If DLongToString(elementID) <> "0" Then
Set oArc = ActiveModelReference.GetElementByID(elementID) ' get Arc with given ID
Debug.Print DLongToString(oArc.ID), CStr(oArc.ID64)
ActiveModelReference.RemoveElement oArc ' delete element from active model
elementID = DLongFromString("0")
End If
End Sub
