NOTE: Information not present or linked: was either not available at time of release or, is will be added shortly.
See: Official Release Announcement
The following methods/functions have been added to this release of the SDK
DGNPLATFORM_EXPORT bool SetExpression(WCharCP expression, bool useLastValidValueOnFailure, WCharCP failureValue = nullptr);
Set the name of the parent category. DGNPLATFORM_EXPORT BentleyStatus SetParentCategory (DgnTextSnippetCategoryPtr parent);
Get/Set auto ambient. bool IsAutoAmbient ( ) const void SetIsAutoAmbient ( bool isAuto ) Get/Set percentage of solar. double GetPercentageOfSolar ( ) const void SetPercentageOfSolar ( double percentage )
Check if a PickList is used by elements. static DGNPLATFORM_EXPORT bool IsPickListUsedByElements ( UInt32 pickListId, DgnFileR dgnFile)
Find the definition of a unit from the user's workspace by matching one of its labels. static DGNPLATFORM_EXPORT UnitDefinition GetByLabel ( WCharCP label, bool alsoStandard = false )
Construct a parser with default settings. static DGNPLATFORM_EXPORT DistanceParserPtr Create ( )
Bentley.DgnPlatformNET.ItemTypeText public static ulong GetDependentElementId(Bentley.DgnPlatformNET.Elements.TextNodeElement textNodeElement) public static System.Collections.Generic.IList<System.Tuple<ulong, Bentley.DgnPlatformNET.DgnModel>> GetDependentElementInfos(Bentley.DgnPlatformNET.Elements.TextNodeElement textNodeElement) public static bool GetRelatedClassesOfTextNode(Bentley.DgnPlatformNET.Elements.TextNodeElement textNodeElement, Bentley.DgnPlatformNET.DgnModel model, System.Collections.Generic.IList<string> classList)
Bentley.DgnPlatformNET.DgnTextSnippetCategory public void SetParentCategory(Bentley.DgnPlatformNET.DgnTextSnippetCategory parent)
Bentley.DgnPlatformNET.AmbientLight
public bool IsAutoAmbient { get; set; }
public double PercentageOfSolar { get; set; }
Bentley.DgnPlatformNET.ParameterDefinitions public System.Collections.Generic.IDictionary<string, string> GetParameterSetValues(Bentley.DgnPlatformNET.ParameterDefinition definition, System.Collections.Generic.ICollection<Bentley.DgnPlatformNET.ParameterSet> set, Bentley.DgnPlatformNET.ParameterCsvSectionPresenceFlags sections) public bool SetVariableValue(Bentley.DgnPlatformNET.ParameterDefinition definition, string value, double unitFactor) public bool SetParameterSetValues(Bentley.DgnPlatformNET.ParameterSet set, System.Collections.Generic.IDictionary<string, string> valueList, double unitFactor) public bool SetParameterSetValues(Bentley.DgnPlatformNET.ParameterSet set, System.Collections.Generic.IDictionary<string, string> valueList, double unitFactor, string masterUnitLabel, string subUnitLabel)
Bentley.DgnPlatformNET.PickListLibrary public static bool IsPickListUsedByElements(uint pickListId, Bentley.DgnPlatformNET.DgnFile dgnFile)
Bentley.DgnPlatformNET.UnitDefinition public static Bentley.DgnPlatformNET.UnitDefinition GetByLabel(string unitName, bool alsoStandard)
