Native (C++) - Step By Step Guide
This series of articles will provide you a step-by-step guide to learn MicroStation CONNECT edition MDL development.
Chapter 0: Introduction and Prerequisites
Chapter 1: Building a simple MDL Application
Chapter 2: Detailed explanation of mke file
Chapter 3: Creating elements in MDL applications
Chapter 4: Adding commands to MDL applications
Chapter 5: Creating a VS project and debugging the application
Chapter 6: Implementing Interactive tools using DgnTools Class
Chapter 7: Adding User Interface to a MDL Application
Chapter 8: Launching applications through the customized interface
You can also download the source code of this training from
here
