Bentley Descartes provides many functions for modifying the pixels' value of a raster, of any pixel type, provided that the file format used to store the raster is supported in write mode.
The Touch-up tools are use to modify the content of pixels with tools which emulate physical brushes and erasers.
The Paint tool allows the user to paint on the image as if was painting with a brush on a physical canvas.
The brush method, also known as "interactive painting" requires much dexterity and can lead to the coloring of undesired area.
The basic shape of the three types of brush are shown below.
The area method is different from using brushes in that the area to be painted is selected and the brushing of this area is done instantly instead of brushing the area manually with one of the brushes. The different ways of choosing the area is shown in the picture below. Note that it is possible to choose a color mask which will work has a stencil and impedes the modification of all pixels in the area that are masked. It is also possible to choose the whole image as the area. Beware that when using image as the area all the pixels of the image are going to be painted unless some of them are masked. In other words, the contents of your image will be loss if no mask has been set.
Brush Method vs Area method
Productivity Tip : If you want to paint basic geometric form on the raster, use the stamp vector tool.
The Erase tool is quite similar the to Paint tool except that the color is always fix to black and no color mask can be chosen.
The Cleanup tool allows the user to remove small aggregate of pixels of different color than the surrounding pixels. Such speckles often occurs on image created from scanned document.
The flood tool allows use to fill an empty area with just one click. The flood tool is similar to the famous paint bucket tool found in many image editing software, but it works only on binary raster (i.e. : black and white or two colors).
Below is a small example of using the flood tool to fill with green a small area on the binary raster, the left picture representing the image before the flood operation, and the right, the image after the flood operation.
The combine tool can be used to combine the foreground data of two binary images together and save the result in a destination binary image.
This section presents an example for each different combine type available. The two binary rasters used as the sources are presented below. Note that the source 1's foreground color is white while the source 2's foreground color is green and that some foreground pixels from both binary raster are overlapping in two distinct areas.
Source 1 In Front Of Source 2
Source 2 In Front Of Source 1 |
When the AND combine type is chosen the overlapping pixels of both source rasters at one location are AND together. If both pixels have a value of 1 (i.e. : foreground color), the destination raster will have its corresponding pixel set to 1. In all other case, the destination raster's corresponding pixel will be set to 0.
Destination With Sources |
Destination Only
Usage Tip : The AND combine type is useful for finding overlapping foreground areas in both source rasters.
When the OR combine type is chosen the overlapping pixels of both source rasters at one location are OR together. If at least one of the source pixels has a value of 1 (i.e. : foreground color), the destination raster will have its corresponding pixel set to 1. The destination raster's corresponding pixel will be set to 0 only if the overlapping pixels in both raster are set to 0.
Usage Tip : The OR combine type is useful for mergin together two binary rasters or part of two binary rasters.
When the XOR combine type is chosen the overlapping pixels of both source rasters at one location are XOR together. If one and only one source pixels has a value of 1 (i.e. : foreground color), the destination raster will have its corresponding pixel set to 1. The destination raster's corresponding pixel will be set to 0 if both overlapping source pixels have the same value, being 0 or 1.
Destination Only |
Usage Tip : The XOR combine type is useful for finding all foreground data that are not overlapping. In that regard, the XOR type is the opposite of the AND type.
When the compare combine type is chosen the pixel value of the first source is compared with the second source. The foreground pixel of the first source raster will be written to the destination raster only if the second source raster's overlapping pixel is not set to 1. Otherwise the 0 will be written to the destination raster.
Destination Only |
Usage Tip : The compare combine type can be used to determine the pixels in the first source raster that are equal to 1 and for which the corresponding pixels in the second source raster are not equal to 1.
The rasterize tools give the user different possibilities to rasterized vectors hovering on a raster. The process of rasterizing consists to convert vector element hovering a raster to a series of pixels in the destination raster representing the vector element.
The Stamp Vector tool can be use to stamp selected vectors directly to an attached raster. Stamping vectors can be very useful when basic geometric needs to be painted on a raster.
Drawing a simple red circle of a given radius and its the radius dimension can be tremendously complicated and time consuming to do with the touch-up tools. Combining the vector drawing capabilities of MicroStation with the rasterizing capabilities of Bentley Descartes makes this task very easy to accomplished. To prove that this task is quite
Productivity Tip : Check the Use this View setting so you don't have to select the view each time of want to stamp a vector.
Sometime you have many vector elements that you don't want to stamp directly on the raster under the vectors. In that case you may use the merge tool to rasterize all the vector elements and merge them with the raster under those vector elements to form a new raster.
Since line weights and styles always display at the same ratio regardless of the zoom factor, for each level of zoom the element covers more or less pixels. For example, when zoomed out really far, the element covers more pixels than when zoomed in very close. It is this coverage, in Working Units, that is used to modify the Line Mapping Settings.
The Line Mapping Settings dialog box is used to set the mapping between the vector element's line weight and line style parameters and the resulting line weight and line style of the rasterized vector elements (i.e. : pixels representation of the vector element).
The cut / copy / paste functionalities are similar to the standard cut / copy / paste functionalities found in numerous applications like text editor. In Descartes, the cut / copy / paste functionalities work on the pixels composing one or many rasters.
The Local Transform tools are used to do basic editing operations within the boundary of the active image. The basic editing operation are : copy, move, scale, rotate, mirror and warp.
In Descartes V8i two more complex and complementary editing tools have been added to the local transform toolbox. These tools allow the user to cover-up or clone a specified area with another area in the same image. Both tools' setting dialog are identical.
This section shows what can be achieved with the Clone Area and Cover Up Area tools. The goal here is to cover-up / clone the boat at the top of the following image.
- Covering-up the boat
The image below show the image after the boat at the top of the original image has been covered-up. The power of the Cover Up Area tool is based on the fact that, in an image, the neighborhood of an area containing background image data (in that example, water) can be copied over this area to cover up some object (in that example, the boat) with background image data. Note that the selection of the Show destination option results in the drawing of the left double rectangle in the image below. This rectangle is deleted once the operation is terminated.
Productivity Tip: Turn on the feathering to ensure that the border of the Cover Up Area or Clone Area doesn't appear in the resulting image.
- Cloning the boat
The Clone Area tool is very similar to the Cover Up Area except that now this is the selected area that is used to cover up another area instead of being covered up. The example below shows the boat at the top of the original image being cloned.
The Cover Up Area or Clone Area tools can be used interchangeably. In the cover-up example above, the Clone Area tool could have been used to clone the water body on the boat. The major drawbacks of using the Clone Area tool to cover-up some object is that you need to estimate the size of the object to cover when selecting the clone area and that the clone area chosen might not give the anticipated result. Using the Cover Up Area tool have none of those drawbacks when having to cover-up an area.
Productivity Tip: If you have to cover-up (i.e. : erase) a foreground object with the background image data, use the Cover Up Area tool. If you have to clone a foreground object on the background image data, use the Clone Area tool.
The color mask can be used as a stencil for ensuring that only some determined regions are modified while other remains unchanged when using the standard raster editing tools. The stencil is described in term of the different colors than must not be modified, thus the name color mask.
Colors can be easily added to or subtracted from a given mask by using the tools Add to Mask / Subtract from Mask. These tools allow the user to select an image's area containing pixels whose colors need to be added to or subtracted from a given color mask. Note that the Subtract from Mask tool's settings dialog is the same as the Add to Mask tool's settings dialog shown below.
The hilite mask tool allows the user to turn the hilite on for the selected color mask.
The color mask dialog can be used to manage (create, delete, add colors, remove colors, etc...) color masks. A mask can be used with any image of any pixel type. Color mask cannot be used with binary image.
With Bentley Descartes it is possible to edit 2D raster not only in 2D model but also directly in a 3D model.
When working on an 2D image in a 3D model it is important to consider the visual deformation of the raster when viewed through a view that is not on the same plane as the raster. This visual deformation is the result of the raster's pixel being reprojected from the raster plane to the view plane. When dealing with images that have a 3D orientation, several tools provide the Work in Image Plane option which projects all data points perpendicular to the image coordinate system.
When this setting is off, the data points are parallel to the view. However, when it's turned on, the data points lie on the same plane as the 3D oriented image. The image on the left shows the setting off, while the right image shows the datapoint placement when the setting is on.
