Fault Current values for Special Supply type
 Product(s):Hevacomp Connect
 Version(s):V8i (N/A)
 Environment:N/A
 Area:N/A
 Subarea:N/A
When specifying a special Supply type, you are required to enter a fault current.
Method
You should note that for:
