| Product(s): | Hevacomp Mechanical and Electrical designer | ||
| Version(s): | V8i (version number) | ||
| Area: | N/A | ||
| Subarea: | N/A |
When running a particular program from Bentley Hevacomp, an AutoCAD installer message appears.
This is a known issue with the Autodesk installer, and can also be seen running Office applications or other software.
For information and solutions, see this article on the Autodesk Knowledge Network.
More information can be found on the Autodesk forum.
