Bentley Example - MicroStation VBA Events
The attached MSVBAEvents.mvba example can be used as a basis/template for a multitude of general VBA event testing needs and handle a number of common needs like Launching VBA Applications and Using OnProjectLoad or DesignFile Open/Close, Model Activate before/after, EnterIdle, View Redraw before/after, and some very basic UserForm events too.  Note there is a use of "Stop" in the OnProjectLoad event to open the VBA debugger so you can view the (trace) events in the order called - just press F5 to continue.
SAMPLE TRACE OUTPUT:
Sample Trace Output
EXAMPLE PROJECT:
Download: MSVBAEvents.zip
