Build and Compile Examples
MicroStation CONNECT SDK Examples can be readily compiled using any of the workflows listed below.
Step 1:  Open the MicroStation CONNECT Developer Shell (TIP: Set shortcut properties to ensure you - Run as Administrator)
Step 2.  Compile one or more examples...
  1. Compile/Build All Examples
      1. buildallexamples
  2. Compile a Single Example
      1. pushd DialogBoxes\myapp
      2. bmake myapp
  3. Compile a Single Example for Debug
      2. bmake -dDEBUG myapp
  4. Compile a Single Example with Full Build Logging Details
      1. pushd dialogboxes\myapp
      2. bmake +avilC myapp
