| Product(s): | Hevacomp Mechanical and Electrical Designer | ||
| Version(s): | V8i (N/A) | ||
| Area: | N/A | ||
| Subarea: | N/A |
Bentley Hevacomp has stopped working after the Windows 1803 update. When attempting to launch Connect, Design Database, Netsys or System Builder, a "Run Time Error 91 - Object Variable or With Variable not set" is immediately encountered.
A programmatic solution for this issue has been generated. Please patch your installation with the latest update.
