Sign MicroStation MDL Applications
Verify your certificate is properly inserted into Microsoft's local certificate manager store (certmgr.msc) then sign your .ma (rsign.exe) using the certificate common name (-cn) and sign your .dll (dllsign.exe) similarly. If any errors occur Generate a MicroStation digital signature diagnostics log as follows:
MS_SECURITY_DIAGNOSTICS= 1
MS_CONSOLELOG=c:\ustnlog.txt
Attached is Digital Rights Impact on Application Development; an older document providing an overview of MDL application signing: process, tools, and additional validation steps.
This is an example that shows how to manually sign your .ma file (vs. rsigncmd in your .mke/.mki file) you may want to try using -cn (common name) of the certificate; like this:
rsign -cn "Bentley Developer Support" myapp.ma
To validate an MDL application (.ma, .mvba, or .dll) signature:
checksignature --ll myapp.ma
checksignature --ll myapp.mvba
checksignature --ll myapp.dll
Alternate ways include:
checksignature -x myapp.ma, or
rdump -t'dSig' myapp.ma
For additional information on Signing Applications for use in MicroStation Security Modes see topics: Digital Signatures and Tools for Signing.
