The following table provides reference with respect to MicroStation Design Files (V7 and V8) formats and the Solids Working Area construct, limits and available tools/workflows.
MicroStation V8 (32-bit) |
MicroStation V10+ (64-bit) | |
Open Buildings Designer (64-bit) |
Ribbon: Building Design > View > Solids Working Area > Toggle SWA Display Key-in: SOLIDSWORKINGAREA SHOWAREA < ON | OFF >
Ribbon: Building Design > View > Solids Working Area > SWA Audit split button > Zoom SWA Extents Key-in: SOLIDSWORKINGAREA ZOOMTOAREA
Ribbon: Building Design > View > SWA Audit > Show Outside Elements (Incremental) Key-in: SOLIDSWORKINGAREA SHOWELEMENTOUT |
SEARCH: "Solids Working Area" OR "SWA" OR "SolidsWorkingArea"
