| Product(s): | Hevacomp Mechanical and Electrical Designer | ||
| Version(s): | V8i (N/A) | ||
| Area: | N/A | ||
| Subarea: | N/A |
Under certain circumstances Network drives may not be visible in Hevacomp Project Explorer.
You should then be able to navigate to the network location to access your Hevacomp projects.
