MDL FAQ
Use this page to see frequently asked questions.
Related Topics:  Best Practices, SyntaxHighlighter, Terminology, Secure Upload
TIP: For linked content presented in different languages, consider using a browser extension like: Google Translate > Translate Page.
Getting Started
.NET Addins
Access/Permissions
Code Migration/Conversion
C++/CLI
Debugging
MicroStation CONNECT SDK source code can be readily debugged using Microsoft's Visual Studio Debugger.
RELATED: Debug V8 MDL Apps, Debug MicroStation VBA Apps, Search Paths
Dialogs
MicroStation CONNECT Dialog Box and Item sizes
MicroStation CONNECT switched to using a more modern Windows 10 default system font (From: "Microsoft Sans Serif", To: "Segoe UI"). Therefore any custom Dialog Boxes and Items sized using XC & YC macros will be respectively change their calculated sizes/proportions based on the default system font the respective MicroStation product line was compiled to use.
For additional dialog box migration and creation, please see these helpful MicroStationAPI.chm help topics:
  • Migrating Dialogs
    • CONNECT Edition User Interface Porting and Enhancements
  • Creating New Dialogs
    • Dialog Box Manager Overview
    • Migrating to Layout Manager
Elements
MicroStation classifies and organizes graphical (vector) and metadata information using a number of well-defined conventions. Please find information related to the most common concepts and methods available:
Security
Determine if your .NET Project requires running in a High Security mode. See: Security Configuration Variables
MS_SECURITY_LEVEL   : System         = NONE
MS_SECURITY_SPC     : System         = C:\ProgramData\Bentley\CONNECT Edition\Configuration\Organization\SPC\*.cer
Search Paths
MDL (Native Code. .ma, .dll) MS_MDL (Primary MDL application search path)
MS_LIBRARY_PATH (Primary native code library path)
MDL (Managed Code. .dll) MS_ADDINPATH (Primary .NET addin path)
MS_ADD_DEPENDENCYPATH (EC library path)
MicroStation VBA (Interpreted Code. .mvba) MS_VBASEARCHDIRECTORIES (Directories to search for VBA projects)
Related: Configuration > Application Config File
Virtualized Environments
Bentley Software - Virtualized Environment Support
