| Product(s): | Bentley Descartes for MicroStation | ||
| Version(s): | 08.11.09.601 | ||
| Area: | Tools | ||
| Subarea: | Edit |
• And - The destination file contains only the overlapping regions of the two source images.
• Or - The destination file will contain all of the raster data from both source files.
• Xor - The destination file contains only those regions that do not overlap one another.
• Compare - The destination file contains only those regions of the first source file that are not overlapped by the second source file.
| Original Author: |
Frank McAllister |
