| | Product(s): | Hevacomp Legacy | |
| | Version(s): | V8i | |
| | Area: | General | |
This article offers guidance on working remotely with Bentley Hevacomp.
Note: The on-demand webcast "Working From Home with Hevacomp" is now available here. Or you can copy and paste this link: https://event.on24.com/wcc/r/2282778/5D1B44E5E3757E2FDBF15B44064BD2FD
A number of other Working From Home product webinars can be found here.
Machine Requirements
Bentley Hevacomp should function fine on most machines, however we would advise that the following requirements are met:
Downloading Hevacomp
- Downloading Bentley Hevacomp V8i (v26)
- You may need to request download permissions from your Account Administrator. To obtain download rights, please see here.
- We appreciate that your login details may be saved on an alternate machine - should you not know your password simply click the Forgotten password link:
License Activation
To activate Hevacomp, you will need to enter your activation key. Please find guidance on how to do so below.
Should you have any issues activating, please rest assured that the software will still work for a limited time, in trial mode. Please contact us for assistance if required, before the trial period expires.
Accessing your projects
We appreciate that your working projects may reside on a network drive. These can be accessed as usual, as long as the drive is mapped to your machine.
- If using the Windows Path file method, then you can then simply navigate to your network folder, and then to the project folders. Should the network drive not appear, see:
Network Drives Not Visible in Project Explorer
- Note if using the Project Explorer method you may need to change your project paths to the network location.
Accessing Product Documentation
How to Get Help
Further general guidance from Bentley Systems on this matter can be found here.
