| Version(s): | 08.11.09.608 | ||
| Area: | Raster | ||
| Subarea: | N\A | ||
| Original Author: | Anil Aktug, Bentley Technical Support Group | ||
You can use Bing Maps content as a live raster;
To Attach Bing Maps
Go to Create a Bing Maps key and obtain a Bing Maps Key.
The Raster Attachments Options dialog opens.
After obtaining the key
Create a new configuration variable named "MS_RASTER_BINGMAP_KEY" and give it the value of your
Bing Maps key. Example, "abcdefGhiJklmnop_qrstuvwXyz".
Save the variable then close and reopen Your Bentley Software
Go to File > Attach > Bing Maps… in the Raster Manager dialog box.
The "Raster Attachments Options" dialog opens.
There are three options to choose from layers
Road: a cartographic type map with roads and place names
Aerial: aerial photography of the earth
Aerial with labels: a hybrid of aerial photography and roads and place names
You could also use the keyins >
raster attach fixed http://www.bing.com/maps/road
raster attach fixed http://www.bing.com/maps/aerial
raster attach fixed http://www.bing.com/maps/aerialwithlabels
Bing Map usage is subject to Microsoft's Terms of Use https://www.microsoft.com/en-us/maps/product. In particular, there are some restrictions on printing. For details, refer to the web page https://www.microsoft.com/en-us/maps/product/print-rights.
http://communities.bentley.com/products/geospatial/desktop/f/5924/t/102800
