Workflow: Prepare resources for publishing in 3D Mapping Cloud and 3DM Publisher
This page describes the steps to take to get your resources in 3D Mapping Cloud or 3DM Publisher - the sharing products of the Orbit portfolio.
There is a distinction made between three types of resources:
  1. Standalone resources: these can be a vector file, an ortho image, a WMS service, a textured mesh, etc.
  2. 3D Mapping data: a combination of several resources (images, point clouds, photo positions, trajectory data) that can be organized in an Orbit run and used as one resource in Orbit products. More information of the concepts of an Orbit run can be found on the 'Getting started with Orbit 3DM Desktop' wiki page.
  3. Orbit 3DM Run Export from ContextCapture v16: This applies to the specific case when your 3D Mapping data is an export from ContextCapture v16, using the export option for Orbit within ContextCapture. More information on how to do this export can be found here.
STEP 1: ACCESS SHARING TOOL
STEP 2: ACCESS PREPARATION TOOL
STEP 3: OPEN DATA
STEP 4: CONVERT
STEP 5: OVERVIEW IN CATALOG
How to manage your resources in the Catalog Tab (https://orbitgt.com/kb/catalog) ?
Choose the type of resource from the dropdown.
Choose the subtype with the bullets (by default, ‘None’ is selected).
Each column consists of metadata of the resource
Right-click on a selected resource to see the context menu of the resource.
STEP 6: ADD TO SHARING TOOL
2. 3D Mapping data
STEP 3: OPEN DATA
STEP 4: CONVERT
In the Catalog, calculate image availability and data volume for the run.
--> Update your run to solve the issue and calculate image availability and data volume again.
3. Orbit 3DM Export from ContextCapture v16
STEP 3: OPEN DATA
STEP 4: CONVERT
