ContextCapture Master errors after start-up on windows 7 Computer
Bentley Technical Support
 Product(s):ContextCapture
 Version(s):04.04.10.336
 Environment:Windows 7 64
Error or Warning Message
"The application was unable to start correctly (0xc0000005)."
Explanation
On a Computer running Windows 7 when you start ContextCapture or ContextCapture Center Master the software crashes with the following error:
How to Avoid
This is an issue that the ContextCapture Team are currently investigating. It occurs on systems that have both an Integrated and NVIDIA Graphics card (usually laptops) installed. Unfortunately, we have no short-term fix and our best advice is that you continue to use an earlier edition of ContextCapture such as Update 8 (04.04.08.561). We are thoroughly investigating the cause of this issue and are looking to release a resolution as soon as possible..
Please Note:
This issue only affects users of Windows 7 with ContextCapture versions 04.04.09.516 (Update 9) and 04.04.10.336 (update 10). If you have Windows 10 or Windows 8.1 you will not be affected.
If you are affected by this issue please contact Bentley Technical Support who will provide you with the working version of ContextCapture / ContextCapture Center.
 Original Author:Felix James
