Smooth Surfaces in ContextCapture
Question:
Does ContextCapture work on smooth surfaces like a white wall?
Answer:
No, in such a case there will usually be a waffling effect. To remedy this, consider using black and white targets to facilitate the creation of automatic tie points.
